Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
you can snip it off, or leave it there but safe.
Double insulated means the fitting is or the cables are double insulated.
A symbol with two squares one inside the other.
Don't confuse low voltage with extra low voltage or SELV
It is not a good idea to snip the earths off. Terminate them correctly in a choc block making sure you have put some sleeving on first. If your electrics need to be checked for any certification in the future the earths are needed to do R1,R2 tests.
