Earthing false ceiling?
10 Dec 2007
London
I installed a false ceiling in my kitchen together with low voltage lighting before 2005. (introduction of Part P I beleive). Should I have connected the metal frame of the false ceiling to earth?
What that document doesn't consider is the case where a cowboy comes along after you and doesn't fix the cables properly. if the grid isn't earthed and it digs into a poorly fitted cable.......
So based on that argument should all joists be doubled in size just in case a cowboy comes along and drills 50mm holes everywhere?
The trouble with willy-nilly earthing is it can and does cause more problems than it solves.
Only if someone else is paying :D
Indeed, I could think of very few worse places to install a BS951 clamp... :shock:
