- Joined
- 10 Jan 2023
- Messages
- 3
- Reaction score
- 0
- Country
Hello all. I'm hoping to pick your collective brains on this subject.
We moved house 12 months ago and I am gradually checking out the plumbing and wiring etc.... I want to understand exactly what I have got and what I am missing in case we do any future work on the house - it's a 1960's bungalow by the way.
I can't see any earth bonding in he house at all with regards to stopcocks, nor any supplementary bonding anywhere (yikes!)
There are 3 seperate stopcocks in the property bringing mains water from outside (yes, Three!). One is in the attached garage and is just for outside taps etc. One is in the bathroom as the principal stopcock and the 3Rd is under the kitchen sink. They are all old and copper. 90% of our pipework around the house is sill copper, but with some plastic for more recent renovations (before my ownership). There is also a gas meter in the garage but that doesn't seem to have any earth bonding either.
I assume that I need a 10mm bonding earth cable from each stopcock back to the consumer unit.
To keep things tidy, I can run a cable up through the loft and drop it's where needed, but do I need 3 seperate cables running from the CU or can it be one cable that is then spurred via a junction box or some such method?
Forthe supplementary bonding, I assume it's ok to use 4mm earth and clamp between pipes etc.
Finally, the electric shower will need cross bonding. Does this require a 2nd earth cable from the shower unit itself or can it be run from the 60amp fusedvswitch outside the bathroom?
Some of this I may do myself, but I will get quotes for some of the work too. I just wanted to understand my best options before a local electrician tries to dupe me into paying too much or not let me make it as neat and tidy as possible!
Look'g forwards to all your help and suggestions. PS: moving house is not an acceptable suggestion!
Many thanks,
Chris
Many thanks,
Chris
