On tracing my wiring I've found a few scary things. The main earth from the CU just connects (loosely!) to a cold water pipe. It's in the same room as the stopcock, but not directly 'near' the stopcock. (There is no supplier earth so I've already asked them if they can provide a PME but it's going to be weeks before I get an answer). The incoming water is on lead pipe
and the stop cock is a soldered joint to the copper internal piping. I know I have to bond unbroken from CU back to the stopcock, but I guess there's probably a decent earth there anyway?
The question is, do I need to knock in an earth rod or is it ever ok to use the water main?
There's also an earth bond iacross all the piping to the combi. It's on an unbroken 16mm cable back to the CU. If I do need an earth rod, can I connect it directly to this cable, and should it be disconnected from the pipework bonding to leave that as supplementary? The combi is in a kitchen where the sub flloor is nice and damp so it's possibly a good spot for a rod.
