I've recently had a combi installed and, due to the fact that the gas meter is a long, long way from the electricity meter they said it would be easier to put in an earth rod to connect the gas pipe to earth, rather than take 16mm cable all the way back to the electric meter. I didn't see them test the rod, but maybe they did while I wasn't looking.
Firstly question, was it necessary to earth the gas pipe between meter and boiler, when
1) The gas supply pipe is plastic
and
2) The water system uses exclusively plastic pipes (apart from the first 2 metres from the boiler which are all copper.
Second question, if my electricity supply is PME, and I add an earth rod, does it in any way change the parameters of the protection systems in the CU? I thought normally PME doesn't use any earth rods, I've not seen any diagrams showing that, so was just wondering... Perhaps it's a dumb question.
thanks,
NN.
and
thanks,
NN.
