How/why did you investigate ?
I was getting a small shock on microwave on that socket, hence opened the socket, only to find live n neutral
cheers
joe
PBoD, if I dare to make a suggestion .... for very good reason, you often make the above statement in your responses to OPs, but I wonder if many DIYers actually understand what sort/piece of equipment you are referring to. Whilst I know what sort I things I would use for proving dead, even I am not at all sure what you mean by an "approved voltage indicator" -"approved" by whom? Might there not be a more DIYer-friendly form of words that you could use?... prove circuit is dead by using approved voltage indicator and ...
Fair enough - and, as you say, I am already aware of all that. However, my point remains that when one is giving this important advice to OPs in this forum, one should probably try to use language which will have some meaning to them. It's a bit of a vicious circle - since anyone who needs to be told about 'testing for dead' is probably not going to understand what a 'approved voltage indicator' is!Approved Voltage Indicator is a term I have been brought up with when describing electrical test equipment that is used to test voltage.
And the probes/leads should be compliant to GS38, which I am sure you are aware of John, but for those that are not http://www.hse.gov.uk/pubns/priced/gs38.pdf ... Therefore approved by the HSE. Hope this sheds some clarity!
You're not an idiot John, I am sure you fully understand what I mean!but your usual wording implies that the device itself is 'approved', and I'm still not sure what that would mean.
I like to think that I'm not an idiot and, as I said, I fully understand what sort of devices should be used for 'testing for dead'. However, I truly don't really know what is meant by an 'approved voltage indicator' - unless it simply means any voltage indicator which has GS38-compliant leads/probes (and even that would mean nothing to most DIYers).You're not an idiot John, I am sure you fully understand what I mean!but your usual wording implies that the device itself is 'approved', and I'm still not sure what that would mean.
I'm really not getting at you, or being critical - I'm trying to be constructive in the interests of this DIY forum. I'm in a similar 'interesting' position to that of a number of the other 'regulars' in this forum, in that I understand quite a lot, and certainly understand 'electrician-talk' but, at the same time am a non-electrician with a reasonable idea of what the average member of the general public probably understands and doesn't understand.With regards to my terminology and the OPs understanding of them, if they do not understand the meanings, they can ask and I will be pleased to elaborate ...
I cannot find the word "approved" in that document. There is a series of sensibly recommendations about how the equipment should be constructed.Approved Voltage Indicator~~
I've just spent a while trying to put myself into the position of a DIYer who had been told that (s)he needed to acquire an "approved voltage indicator" and who was using the internet to find something suitable to buy.I cannot find the word "approved" in that document. There is a series of sensibly recommendations about how the equipment should be constructed. Approvals are normally issued by independent testing organisations based on the sensible input from HSE and other informed sources.
Is it possible the wiring is in metal conduit and that was relied upon to provide the earth connection?It occurred to me that if this socket has no earth, other sockets may be the same. If I were you I wouldn't use ANY of them until they have been checked and, if necessary, rectified.
I can't believe that someone has installed power sockets without an earth, especially in a kitchen.
