- Joined
- 25 Oct 2006
- Messages
- 2
- Reaction score
- 0
- Country
\\\"If the dimmer switch is metal e.g. brass or chrome, then it should have an earth terminal on the metal case. This should be connected with a short length of earth wire to the earth on the mounting box inside the switch\\\"
Is this the only earthing that\\\'s needed to fit a brass dimmer to metal box? I have 1 way light switch with Live and Neutral wires connected (no extra earth) and want to replace with brass dimmer, if I attach an earth wire from brass dimmer to earth on metal box is this sufficient earthing?
