Easi-Fill Use by date
2 Feb 2016
Hey all,
Need to do some filling on my walls and have a 10kg bag of Easi-Fill that is 2/3rds full. I'm sure the Use By date went out in around Aug but just wondering if, in relaity, that date is flexible and can still be used? I'm not sure what the effects of using it out of date would be.
Cheers,
-NS
I used out of date plaster for a few touch up jobs a while ago, sorry I can't remember whether it was bonding plaster or fast set (easy fill). It performed the same but started to set much quicker. It should be ok for touch up jobs, just mix enough for maybe 10 mins work at a time.
Edit... or mix up a little and see how long it takes to go off.
I've used out of date plaster many times without any problems at all, but then I know It'll go off quicker, so I'm careful on which job I use it on. It's great for smaller jobs/patching etc, but you wouldn't use it on, say a large area, just in case you lose it. I wouldn't mix it with new, in-date plaster either, unless you're looking for a faster set. It's all about knowing your capabilities. Don't throw it away though, just be selective where and when you use it. Most plasterers would have the odd amount in their van etc.
I've had the same bag of easifil on the go for the best part of two years now and it's still fine. Don't know how it would still perform as a full on joint filler for which it was intended, but is still fine as a decorating filler
