hi my daughters machine has been playing up so i checked the pump and removed a 20p coin and a hair clip. the problem is that when it is switched to quickwash it makes a noise like its filling up with water but nothing comes in. previous to this it wouldnt pump out (probably because of the coin). when i removed the coin some water drained out of the pump cover and i could see the impeller spinning freely without any noise. whilst it was supposed to be pumping out i opened the cover and a very small amount of water trickled out and there was a small flash under the machine and the drum span momentarily and stopped again. any help would be great. thanks, mark/
