Hi! I need some advice before I call the engineer out.
I had the above boiler installed last year november. About 3 months later I noticed the boiler was taking too long to fire up when the temp had dropped. There's no problem when you switch the heating on for the first 2 hours or so, rads are hot to touch. When the room temperature is reached the boiler switches off and it should fire up again when the temperature drops. But I noticed it was getting very cold before it fired up, I waited about 55 mins before it came back on again by that time the house was cold again. The room thermostat is located in the hallway and is set at 20 degrees. I think the thermostat is working as I can turn of the heating when I turn it and make the boiler fire up sooner when I increase the temp but I don't want to increase the temp because I want to save on fuel. Appreciate some advice, thanks!
