Hi all,
So for a few months I've been putting up with my hot water no longer being hot- just barely luke warm as frankly I'm not in a position to replace it and it's been working fine up until the NTC sensors were replaced.
Now until today theres been nothing obvious about whats happening, say the resting temp on the boiler was 20oc, you'd run a tamp and it would reach the target which is set to 65oc, but then fairly quickly start cooling down 1oc at a time before settling around the 40oc mark for a good 10-15 minutes. Wouldnt matter if the heating was on or not, or had been on or not. Occasionally in the shower it would kick back up to 65oc briefly before doing the same thing. Even more rarely, it would keep to the temp so you could have a normal shower.
Anyway today minutes ago, I noticed the boiler was sat at the reading of 61oc. Note, the central heating has not been on, nor was there any demand. The hot water had also not been running. When I saw this, I turned on the hot tap, when it quickly went up to 70oc before cooling down again...
So my theory is the boiler isn't actually detecting the right temps, thinking the water is probably much hotter than it actually is. This seems logical given it was working fine before all 3 NTCs were replaced... my issue is they've each been replaced for different reasons at least twice, so I'd rather not have to go through the same cycle again if actually this might not be the fault of one of the NTC's but an underlying issue with another component.
Can anyone confirm this is likely an NTC issue, or whether it could be a sign of something else? Be it dodgy heat exchanger?
It will take me months before I'm even close to affording to replace the boiler (which will (fairly) be 95% of plumbers opinion locally due to its age), but I could certainly find the funds to replace a key component if its 90% the likely cause. I'm just trying to avoid the "It will cost £x for the call out to diagnose the issue, then its £x per hour when we return to fit the part" etc. I'm aiming for more a "I've drained the system and here's the part, can you fit it please" when they arrive.
I should also add that at least once every fortnight the boiler would loose pressure, seemingly from the PRV for no obvious reason. Just in case this could help with what this points to (ie faulty expansion vessel).
Thanks and sorry about the essay.
