we have just moved into a flat with E10 electricity supply.
The flat has 3 Dimplex storage heaters and a hot water immersion in the cylinder. All of which are not working.
As a new homeowner; i have tried to research into E10. I conclude that the heaters and the immersion are supposed to heat up when the E10 supply is on at various times of the day. Is this correct?
We have had the hot water immersion changed as we thought it was faulty. This was done prior to finding out the heating doesn't work either!!
We tried to investigate whether it was the E10system/feed that was faulty so we purchased a voltage detector. upon testing the wires to the heaters/immersion @ E10 times; it glows-i.e. a current is running through.
The detector does not glow during non E10 times (as would be expected)
Does this mean all 3 heaters need repairing?!?!? and what is wrong with my new immersion? Since we had it replaced and a current is flowing through it- why are we not getting any hot water?
Sorry for the very inconcise posting, but i am at my wits end and am completely overwhelmed.
Any advice would be gratefully received.
Thank you in advance
