Hello there! I wonder if anyone could help me with my electrics situation.
I live in a purpose-built block of flats and only have electrical heaters and an electrical boiler. My economy 7 (e7) powered immersion stopped working, causing the fuse box to trip. I have not been blessed with trustworthy plumbers as I was advised to put in a new cylinder for the simple reason that the plumber couldn't open up the cylinder to change the immersion. However since then, I have managed to find another plumber who has now changed the immersion and he showed me that the immersion had corroded away due to limescale and wear and tear, causing the fuse to trip. However he said he has no way of testing if it works until the e7 system kicks in at night. So I left the switch on and the fuse turned on too (I had switched everything off when it tripped the first time) and to my disappointment I don't think I have any newly heated up water. I can't tell exactly because my boost immersion was running yesterday. I will keep the boost off all day today to see if the e7 system heats up water. I know that the system works because my storage heaters come on at night. My questions were:
1. Is there a way to check if e7 is heating up water before I run the taps tomorrow morning and feel the water heated up?
2. If water is still not heating up, what could the problem be?
Many thanks for your time and help...
