The case on the front should be sealed shut!
Are you "asuming" that my front cover is off?
I don't need to assume it is. To get to any functional parts on an ecotec you need to remove a sealed cover, its sealed for a reason.
You are assuming that the cover of my boiler is off - its not. I do not need my cover off to see if there is a nipple on the expansion vessel.
Hi
Does the auto bleed valve on the expantion tank have to be open a few turns?
If you havent got an outer cover I suggest you get one, its a big white thing with foam on the inside, its quite important.
drilling the wrong hole is easy to do if your not familiar with the boiler or the mounting diagram.
