Ecotech 835
5 Nov 2020
Hello newbie here
I wonder if anyone could help me, our boiler worked fine for about 18 months.
Then it stop coming on and going off on the scheduled times.
on Automatic it does not come off or go on.
so I have to manually set the temp to come on and below 30 to turn off when I have had enough.
we don’t have any thermostat and it’s all controlled from main unit.
called up live menu
S04 Heating mode – burner ignited
any advice would be great thanks
Have the programmer replaced and why would you have a boiler installed without a thermostat ?
Hi it’s a bungalow we brought it like that.
Thermostat on the boiler but not anywhere else
Don’t think so looks built into
It
The programmer can be removed from the boiler by putting a screwdriver under the plastic trim, turn the boiler off first and then you have a choice of replacing with like or installing a external programmer, good idea to get a thermostat at the same time.
