Efflorescence above DPC - interior wall
8 Jan 2008
Lancashire
Did not want to hijack the other thread until the guy had an answer.
On the post below I describe a problem with paint "peeling" due to this problem.
http://www.diynot.com/forums/viewtopic.php?t=180386
Having searched for the course of the damp I think it is due to no vents into the cavity wall on that facade of the house (all others have it).
The outer wall is stone built from the original materials - with a cavity wall inside.
Would it make sense to say that providing this ventilation should help with the damp - also how easy/difficult is fitting an air brick. I am a relative novice (Keen but not skilled) is it flirting with disaster to do this myself, r is it an easy job? Man in? How much?
Thanks for any help,
B_M
Just because other houses have airbricks does not mean that yours does, and they may have been fitted for different reasons
Ventilating a cavity can cause condensation issues in itself, so do you really mean fit an air brick to ventilate the cavity or ventilate the room?
Either way that plaster is leeching salts and will have to be removed and re-plastered and possibly the wall sealed. Otherwise salts will still come through to the surface. The paint may also be sealing the wall and trapping any moisture, which would otherwise dry off
Hack the plaster off and see if the wall is actually wet - it may take a few weeks to check. It may be just a case of re-plastering with a suitable plaster or render
But you need to identify what is going on with the wall, before you can determine the solution
