egineered floor boards
20 Dec 2008
Lincolnshire
hi all, i laid a floor using 20mm hardwood engineered boards on a floating floor and made the biggest mistake possible by nailing them down so now they creek like mad when you step on them , can anybody give me some surgestions how to stop them creeking with out taking them up, i also layed the same boards in another room with out nailing and its a dream to walk on, all advise welcomed, cheers mick
How did you prepare the subfloor in both areas? It sounds like the subfloor is uneven under the boards, I can't think of any option but the lift the boards and investigate the cause of the movement.
hi crazydaze, the floor was level and not loose or uneven just like the one floor that i did without nailing, all floors were layed on special sticky one side under lay which we got with the boards
