I have an electric fire which is to be mounted to a flat wall surface.
Directly behind the fire is the plug socket which it will be connected to, but obviously with the plug in the socket the fire will not mount flush against the wall.
Can I replace the socket with a switched FCU with flex outlet and connect the fire directly using this to make it more flush against the wall?
