Built in to the unit, or is a separate thermostatic control needed on the supply to the unit?
I know this all sounds kind of dumb, but I've looked at the things and couldn't see any kind of thermostat (at least which you could adjust) on the unit itself.
The dimplex ones don't have a built-in stat. They just come on & off, and the surface temperature is limited by the wattage of the unit, AFAICT.
But you can buy a regulator from dimplex (bit like a dimmer) that you can set so the temperature does not exceed your preset level (the dial is calibrated) for example when installing for the infirm or kids.
I haven't seen any with an on/off switch. I understand the surface temp being limited by the wattage, but what then controls the on/off part?? They surely don't just come on & off randomnly!
