Hello all.
I'm currently designing a new heating system for the local scouts and guides meeting hall.
It is currently rather ineffectively heated by a mish mash of fan heaters, convetors panel heaters and warm air curtains.
The building is a timber construction, but is reasonably well insulated.
The building is often only in use for maybe 2 to 4 hours in an evening, and occasionally on a weekend too.
There is currently no off peak supply and I don't really want the added cost of installing this, plus if OP storage rads were used the building will be warm all day, which is not nesacarry.
The current heating is controlled through a room stat / programmer and contactor arrangement, which if possible I would like to reuse.
I have seen what looks like a standard radiator, but with an internal electric element.
Does any one have any experiance of using these, and if so are they any good, and suitable for this sort of application?
Do they get very hot to the touch? I expect they will, so some sort of guard would be required to protect the youger kids that use the building?
How long do they take to get up to temperature?
Are they reasonably economical to run?
Does anyone know a more suitable / better sort of heater for this sort of situation.
If you have got this far, then thanks for reading
