Electric Shower Low Pressure Problems
I agree that there could be an electrical fault in the wiring, but that would more likely trip the RCD and/or MCB.
Not nessecarily. A loose neutral in a shower switch can smoulder for months undetected. :wink:
I know, but people still scan these when they have a new problem. I've seen this problem appear to go away when the wiring is looked at. May not be the cause, but no harm in getting it checked out.
can anybody tell me why my triton opel power shower is running cold .the red light on the hot water stays off and the red light on the low pressure on all the time meaning no hot water
Check the stabiliser pressure switch is activating the micro switch on the base of the pcb properly.
Hello everyone in this forum
i know this thread is a few years old but i could really use the help.
I have low pressure from my electric shower. it is a dimplex galaxy g8000si. I have read kevnurse's instructions about turning the shower to cold and to see if pressure increases. I tried this and it did. when i decrease the temperature the pressure increases. Now i know what the problem is but i need a little advice on how to fix it. the following link displays a schematic of my shower with all the parts and their location. I do not know which of these i have to replace. I would be grateful for any advice. thank you
http://www.showerdoc.com/shower-spa...-galaxy-g8000si-(electric-shower)---post-2000
As in what ? It's not heating ?
What makes you say you have low pressure ?
That's flow not pressure.
What ? As you don't explain fully your fault.
This shower don't have a LP neon the only symptom this shower will give you if you have LP problem is it won't heat, even then it don't mean it's a LP fault.
