Electric shower question
My choices are:
Get a higher rated CU that allows 2 showers to be fitted but not used at the same time (not ideal and wont get past BC).
The rating of the CU itself is not your problem. It is the ability of the incoming supply to support two showers plus the rest of the house
Get a thermostatic shower fitted. (But gas cost is higher than electric).
Eh? where did you get that from. Electricity cost per KWh is nearly twice that of gas.
You already have and instant heat gas boiler (your combi), that is going to be much cheaper per shower than another electric shower.
CU due to be changed soon as well as the 60A main fuse.
You've arranged that with the DNO then? OOI, how much are they charging you?
previous used to be a 10.5kw which was replaced as broke down but used to trip after 10 mins of continued use understandable as needs 40a mcb
You really should brush up your basic arithmetic skills...
on 32a mcb (which is wrong on paper).
No - plain wrong, not just "on paper". Contravenes the Wiring Regulations and if you have a piece of paper which says otherwise it's a falsehood.
Do you know what size cable the circuit uses, and how it's installed, i.e. buried in plaster/running through thermal insulation/clipped to the surface/etc?
TTC has addressed that.
I'm curious to know how you think it could prevent them both being used together
Do you mean you think it would be so unsafe as to be illegal?
Actually it's about 4x the price per kWh, so as the combi will be < 4x the power of the shower it will cost less to run, (but work much better).
As in a caravan, if it can be gas heated it should be. Electric costs a lot more. I would never go back to electric showers. Thermostatic Mixer showers are soooo much better.
