Hi guys and gals, couple of questions I hope one of you will be kind enough to answer.
We currently have a (broken) 8.5kW Mira Sport. It's connected with 6mm cable and a 40Amp MCB. The consumer unit is RCD protected.
As mentioned, the shower is currently broken, and we are going to get the bathroom redone.
Am I right in thinking that the wiring/MCB setup can only support a 8.5kW shower at max, and if I went to anything else (even only up to 9kW) I would need a qualified electrician (as it involves work in the batrhoom) to upgrade the cable?
What (if any) certification should I receive for a cable upgrade?
How much would it cost? (If I can ask that!)
