Hi guys,I'm new to this forum so please be kind.
I have no doubt these questions have been asked before but I have spent the last hour seaching the threads and can't find the answers. Can you please help
We have a bungalow with a family bathroom which contains an electric shower rated at 7.5Kw fed by 6mm2 cable and protected by a 40A mcb.
All is well.
We are planning an extension which will allow us to increase bedroom sizes and hope to install a further 2 ensuite shower rooms (1 to each) with electric showers rated at 10.5 Kw which will need 50A mcbs. These will be at the other end of the bungalow to the kitchen which houses the consumer unit. Obviously each will need its own independant supply, which will be 10mm2 cable.
Q1. Is there a maximum length of cable between shower and consumer unit.
Q2. It is most unlikely that all 3 showers will ever be used at the same time; can all three be put through the consumer unit on separate mcbs or would you recommend separate CUs for each of the new showers. The CU RCD is rated at 100A
Your suggestions, comments and/or recommendations would be welcome.
All is well.
