Electric Showers
4 Feb 2007
Currently in the process of purchasing an electric shower, quite like the look of Mira's Galena and Azora range and have just seen Triton's Inscription range. Have always had Mira in the past and wondering if anyone has any experiences, pro's or cons on the 2 Mira pieces and any comments on Triton?
I would always choose Mira over Triton, but both makes are simple enough to maintain.
If your local water supply tends toward the hard, then keep the temperature down or be prepared to change out the heater can regularly.
I may be wrong, but I think if you change brand you will have to move cable and cold water pipe 6''as Mira have connections on the left side. Most other brands seem to be on the right for cable and water??
Over 9kw and you may need a 10mm cable, but you need to check.
http://www.electacourse.com/cableselector.html
