Electrical Advice Regarding Kitchen Appliances
by "socket" they mean the double socket.
a double socket is still only rated at 13Amps
by using extension leads in each of the double sockets holes to feed the mentioned appliances, you will probably be drawing more than 13 amps from the socket
while this might be ok for short periods of time, if you intend to dry lots of clothes in one day, then it may cause the socket to heat up and even start to go brown..
