I am planning a kitchen makeover and want to move sockets, install spurs etc.
My fridge and freezer are currently plugged into sockets inside the base units which are not very accesible. I want to install a fused spur taken from a double socket on the wall under the wall units and then run cable down the wall from the fcu to behind the fridge and freezer into a double socket and plug the fridge and freezer into the double socket, that way i can switch them off easily if needed. Is this ok to have only 1 13amp fused spur to feed a double socket for the fridge and freezer, would it trip?
Or would I be better taking a spur from double socket on the wall and feeding 2 fcu's leading down to 2 single sockets? Or would it be better connecting the 2 fcu's as part of the ring circuit to feed 2 single sockets which while I am moving everything else which would not cause much more work?
Cheers for the help
Cheers for the help
