Electrical lead on lawnmower
15 Sep 2010
Norfolk
The Power lead on my Bosch lawnmower that I had for many years the power lead started bunching up, kinking and when I pulled it apart would return to how it was in the end I brought a new lead and in four months it’s gone the same way. What could be causing this please any suggestions.
Tully
The way you wrap it up, and then unwrap it. If wrapped up from plug side then unwrap from lawn mover side, if you wrap up then simply pull cable from coil you will twist the cable a bit more every time.
You are twisting the flex as you coil it up and cheap plastic flex is very susceptible to damage if you coil it up the wrong way. When you coil it, coil it the way it naturally wants to be coiled, maybe putting a twist in to help it form each coil. Get it right and you will have a neat flat coil in you hand. Getting it wrong, winds the flex up inside causing stress and it can burst.
I was taught to wind cables onto my palm and elbow in a figure of eight. The twists are balanced (left and right alternately) and it also has the advantage of being impossible to tangle.
Absolutely not! It twists the conductors and eventually they can break. If I catch anyone coiling my cables - signal or power - that way, they get taught how to do it correctly on the spot! If you want to coil a cable so that it doesn't tangle, then the "over and under" technique is the correct way to do it:
Tully
Its called built in obsolescence, and thus the manufacturer makes more money by selling you a replacement lead that is as crappy as the first one. Make you're own lead out of rubber cable it should last a life time.
Irons are the same, they all come with "non-kinkable" flex, that kinks the first time you look at it.
