ELECTRICAL TIMER
Clearly the wiring you have altered is wrong.
However to have any possibility of locating the problem, a lot more information will be required.
What make / model of timer? What sort of heating system?
Can you get pictures of the wiring?
What exactly have you moved/changed?
Do you have a wiring centre (a square box where all the cables go)?
Do you have a combi boiler or a boiler with a seperate cylinder?
please don't post in CAPITALS.. it's considered shouting on the internet and is rude unless it's to highlight a word or two..
I HAVE MOVED THE CENTRAL HEATING TIMER AND NOW THE THERMOSTAT WONT WORK [/b]
You shouldn't have moved it then, should you.
Recognise the fact that you aren't even bright enough use a Caps Lock key, and get someone competent in.
aaaaaarrrrrrrrrrgggggggggghhhhhhhhhhhhhh.
My eyes are hurting from all that shouting
