- Joined
- 2 Dec 2004
- Messages
- 720
- Reaction score
- 8
- Country
Thanks for all the feedback and ideas.
After consideration and research my proposal is as follows.
1. Install 3 of these heaters in the main living space and bedroom. They are LOT20 standard which means they have stat, timer/programmer and open window detection. That will satisfy the min requirements for the EPC. Lot20 heaters
2. Fit boost controllers to the existing panel heaters. So they won't be on plugs any more so they can't be left on all the time, but can be activated for fixed periods manually using the boost button. Boost controller
3. Fit one of the above boost controllers to the secondary water immersion heater.
4. To the primary water immersion heater, fit a timer/programmer such as Immersion timer
I could actually fit these to both immersion elements rather than a mix of one programmer and one booster.
5. Switch to octopus cosy tariff which gives 3 slots of cheaper energy in the day, then schedule the heaters and hot water to come on during these times.
Does this sound reasonable?
