Hi all
Can someone help me out with this one. I am replacing a shower and the existing wiring is not up to the wiring regs, the cable sizing is correct but its only surface mounted twin and earth and should really be encapsulated or buried and capped. It does have the correct double pole switch and RCD protection.
Since its a replacement I don't really want to go through re-routing the cables but the question is can I get away with leaving it as an existing installation.
Many thanks
Many thanks
