ELV downlighter transformer & wire help!
24 Nov 2004
I am about to buy & install 4 of these downlights:
http://www.tlc-direct.co.uk/Images/Products/size_3/GUDL50C.JPG
for a bedroom lighting project.
How do you go about selecting the appropriate transformer(s) to use with them?
I was kind of estimating 50W each = 200W = 200VA ish, so I could either install 4 of these
http://www.tlc-direct.co.uk/Products/LTYT50.html
(ie, one to serve each luminaire)
OR
cheaper & more efficiently, just 1 of these:
http://www.tlc-direct.co.uk/Products/LTYT250.html
and then wire all the luminaires in paralell from its DC output.
Also,
are there special wiring kits for connecting the luminaires to the transformers and/or each other? or do you just have to buy appropriate wire?
I have installed an ELV downlighter kit before that comprised the 4 luminaires, transformer and a snap-together 12V harness, so never had to worry about the ELV wiring.
Help greatly appreciated & looked forward to with great relish.
In case I appear totally novice-like, I'm technical, competent & experienced with domestic LV but have never DIY-ed ELV lumis before.
transformer for each.
better job, if ? when one fails others are still on
Brilliant, thanks for that.can you offer any comment on the wiring?
