I am about to fit 6 12v 35watt downlighters in the bathroom, i will be using two 105va loop-in transformers with 3 lights per transformer (all from screwfix). This is at the end of the existing 5amp lighting circuit which is in 1.0mm t&e. the bit i don't understand is when you work out the total amp draw for 210 watts of lighting at 12v it comes out at 17.5amp. So how does this work on a 5amp circuit? could anyone clear this up for me please?
Also, the 3 terminals on the secondry side of the tranny's only looks big enough to fit flex into them. what size of flex would be ok? (from tranny to light)
