en suite shower dramas
6 Sep 2005
Dorset
Hi, my en suite (powershower) has been leaking and actually dripped on my head when my wife was showering and i was downstairs watching tv.
Had good look and i am happy that the water pipework and waste pipe is fine. i am sure that the walls are letting water through. All the flooring, plasterboard and woodwork is pretty knackered, so i am going to have to rip the whole lot out.
Once stripped out i will replace the chipboard floor with WBP and any respective woodwork that forms the studdedwalling.
The thing i want to know, is when i replace the 3 plasterboard walls, do i need to plaster first or can i tile direct, if so which side is best?
Also do i need to apply a bond coat of sorts to a) assist with tile adhesion and b) add to the waterproofing?
Also, is there a better way of sealing or waterproofing where the tiled walls meet the shower tray?
Cheers
Lee
Just seen a thread on Tanking, it sounds brilliant, is iteasy to use?
No need to do anything to the plasterboard except tank it. Yes it's easy to use. It's nice when people decide to do things properly.
Thanks,
any views on plasterboard/wall board (dunno the difference) thickness?
9.5 or 12mm
is it best sh plasterbaord tothetop of the tray or down to floor level(leaving a slightgap) and slottingthe tray in after the PB?
As you have the chance to start again, my 2p of advice would be to take ages making sure the walls are square, so the tray will slide nicely in. All my walls are skew, which also makes tiling look shyte if you are not careful.
Tanking on plastered walls seems to be the advice for the best waterproofing. Make sure you use a suitable adhesive for shower areas. Then leave it plenty of time to dry before using it.
No expert, but learn from my mistakes!
