- Joined
- 27 Jan 2008
- Messages
- 28,067
- Reaction score
- 3,407
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have just read an article about saving energy.
However, since electric costs more than gas or oil in the main, there may well be a cost saving using oil or gas instead of electric, if one has the option.
Be it a gaming console, satellite TV box, old fridge, microwave oven, or desk top computer, there will be good and bad, but they are not in general high power users, just some, I tested a Sky+ box, and a free to air box, both satellite TV boxes, the Sky+ used around 15 watt on stand-by, the free to air so low I could not measure it with plug in tester.
The Microwave on stand-by uses so little, and I remember the problems when someone from social services told my mother to turn off the oven at the wall, and then she could not get it to work, as the clock needed setting first, the problems caused by general statements are massive. I have used a plug in tester, and yes there were some surprises, but in both directions.
I have looked at air fryer v microwave, and since the air fryer turns on/off and the microwave is going all the time, air fryer may be cheaper to run, but it depends on what is being cooked.
I was told vented tumble driers cost more to run than condenser type, but that is incorrect, as the vented can often be run at a lower setting, so 90 minutes at 1 kW cost less than 60 minutes at 2 kW. Vented only cost more if used on high setting.
Got the same with using an immersion heater compared to central heating boiler, the immersion heater uses far less energy, but it may cost more, but the operative word is "may", these reports never seem to say "If you don't have off-peak" or any other factor which could change the results.
So how much energy is used to save energy?
and it lists things which switching them off does not really save energy, as in the main, electric used becomes heat, and so ones thermostat just adjusts how much energy is used for direct heating, so swings and roundabouts, no real energy lost.Numerous households might not realise that various home gadgets can quietly drain modest amounts of electricity, accumulating costs on your energy bill over time.
Whilst they're not the primary culprits behind enormous electricity bills, switching them off represents a crucial tactic for energy conservation in every household.
