Engineered flooring - Click system or T&G
21 Aug 2008
Sussex
Hi
I am looking to get some flooring soon and dont know whether to go for the click system offered by some manufacturers or to go with T&G.
The floor will be a floating floor.
Any benefits of one over the other???
More benefits of going for a normal T&G floor than any click-systems, specially in smaller long areas with doors at both sides.
Make sure you glue the T&G's correctly, that's all. It will be easier than all those 'easy' click-systems.
Thanks for that
what makes it better to go for T&G??
Is it possible to cut out the skirting boards as well and slip the t&g underneath them to hide it??
I have a number of the walls without skirting at the moment, but some still have skirting on them
Many thanks
Thanks for that
The easiness of fitting all boards without having walls, doorposts, fireplaces preventing you to make that angle needed with a click system.
Best is always to remove all skirtingboard when you plan to use them to cover the expansion gap to make sure that gap is the same everywhere.
So let me get this right:
take all skirting off first.
Use t&g and glue all edges
Will this be ok for a floating floor on floor boards and concrete?
Will I be able to replace a board at a later date?
Many thanks for your help
You have to use a suitable underlayment (one that contains a DPM when installing on concrete).
You can replace a board in the future when you are carefully. On the new board the bottom groove will have to be cut off and a weight has to be placed on it for a time to make sure it bonds correctly with the neighbouring boards.
