I want some real-world BTDT advice.
The room planned is about 11mx6m with anhydrite screed and wet UFH
I think I want wide-board engineered oak
Questions:
Mostly I've read that screed moisture content needs to be <0.5%CM
Carbide method does not sound like diy task - who do I get to measure it?
Is there another way to know when the floor screed is dry enough?
I think I want to use Elastilon Strong - easy(ish), quick, good sound/vibration damping and good heat transfer
Do I need poly DPM under Elastilon - I read that poly rots with gypsum?
Or should I stick to fully glued? What does this need in terms of sealing the screed first?
I plan to lay the planks parallel to the longer room dimension
Is this OK?
Is there a way to size the perimeter expansion gap vs width?
Does this matter for length?
I'd be grateful for all advice - I don't want a v. expensive screw-up.
Questions:
Is this OK?
