engineered wood floor advice please....
9 Jan 2008
Lincolnshire
Guys
I intend to lay a floating engineered wood floor to my lounge and hall.
I would like to run the boards lengthways through the ajoining door without a break at the threshhold. However this would mean a run of 8.75 meters.
I have tried to research this, and the general thinking appears to be that 8 meters is the max.
What does everybody else think?
Thanks in advance..... Jack
Gals alright too?
Length ways is normally not a problem, my concern is the width from the hallway, say 1 meter, going into the lounge, say 3 - 4 meters wide, specially when the door is located in the middle of the room.
The boards laying partly in the hall will have to cope with two different climates: colder in the hall and warmer, dryer in the lounge.
We normally (especially where hallways are concerned) install rooms as separate areas and install thresholds in between.
Sorry, yes gals are fine, no intention to offend..
Thanks for your help, but you will have to talk to me s l o w l y.
Why is the width an issue but not the length?
Does the wood expand/contract more in one direction than another?
As for your other point, the lounge door is at the end of the lounge, but right in one corner.
I had not considered the different climate in each room, so will break at that point if that is best.
Thanks for your input.[/img]
R i g h t - i n - o n e ;)
The structure of the wood (grain etc) reacts indeed more in the width than it does in the length.
