Hi there,
Yes I know your getting tired of all the problems we have...
When it is very cold in winter the downstairs rooms and one upstairs bedroom will never be warm enough, I have heard that all homes should be able to reach 21C within an hour when it is -1C outside.
So we called the company who installed the system back.
They said that the heating should be more than sufficient; two rooms have radiators with an output of 2135W, the kitchen has a 1500W Myson kickspace and a small radiator which has a heat output of approximately 730W, the passage has a radiator with an output of 1600W, the living room has a radiator which has an output just over 1600W and the porch has a 600W radiator.
We don't mind the porch being cooler but the living areas all struggle to get over 19C on cold winter days, we have the thermostat set at 19.5C-20.0C and the flow temperature is at 82C on cold days.
Since the heating engineer insisted that the output should be enough he said that we could get a bigger radiator in the living room but we would have to pay.
I was thinking that the radiators are not giving out their full output due to the lack of 22mm pipework; starting from the boiler there is 3 metres of 22mm pipework and the rest is 15mm, all the downstairs radiators are fed from a single drop of 15mm pipework.
Could this be the problem?
