Ensuite dampness
6 Jul 2012
Stirlingshire
Hi Folks,
I was wondering if you could help me with a problem we are having in our ensuite?
We have stayed in our house from new which is about 7 years old now. We replaced the shower cubicle just before christmas because the grout had cracked and water was getting in the back. Had to replace the plasterboard on the 3 walls at the same time. Anyway got that all changed out and everything was fine.
Recently though we are starting to see small patches of dampness on the ceiling of the ensuite. There is an extractor fan in there that needs to be put on independently of the light switch. I'm not sure the extractor is working properly but its not making any noise that it hasn't always made.
How can I check if its working and if not how do I go about replacing it. Ideally i would it linked to the light switch.
Thanks,
Mark
If it is turning it should be working.
Most extractors work via the light switch. Unless you are very experienced in this area you should really get an electrician to make the change. You will also need to ensure a timed fan is fitted so it runs on clearing condensation ect after the light has been switched off.
Is there a window in the room? If so open it (when showering) to allow more ventilation.
