Ensuite waste pipe run
2 Jun 2007
Somerset
Hi
I'm currently putting in an upstairs en suite shower room with sink. The run to the soil downpipe is about 35 feet away. The pipe will be under
the floorboards. Is this possible as it wont have much of a drop over that distance.
Are there regulations regarding the drop on the pipe or the distance from the soil pipe?
Andy
Jumping in on this post! Can someone advise what the maximum length you can run waste pipe to, provided you can get the required fall of 1 inch per metre?
Doing a similar job and the distance to the outside soil stack is about 15-20 feet.
Cheers
More discription from me might help!
Sorry max distance to soil is 9 feet, pan connector from W/C is 110mm? Can I take this across 9 feet through a wall and straight into soil stack? Or, can I reduce the pipe size after leaving the pan connector?
My plan would be to use a pan connector that would also take the shower waste. Is this advisable.
Cheers
you ain't going to do it in a million yrs.
you can't notch 40mm out of your joists.
you can't run it 35ft
and last but not least your not going to get the fall you will need.
