anyone used this stuff before im considering buying this to do my whole house with in white.
can anyone give me any info
ebay number 250816485508
thanks
EPDM is synthetic rubber developed by firestone who makes tyres. EPDM is used for ponds, and flat roofs, double glazing units to seal the doors/windows to name but a few it should last years. The item should be okay
Fine provided you have even gaps around windows and doors which are between 3-5mm, if the gaps are uneven it will push out where tight and defeat the object of installing draft excluder.
