Error#1065
  • Thread starter Thread starter DP
  • Start date Start date
DP
10 Dec 2003
Glasgow
I am getting 'player initialisation fault. Reference error:error #1065.
What is it and how do I clear this.
TIA
I assume this is with flowplayer?
If so, are you visiting a site or developing one with this tool?
  • Thanks
Reactions: DP
Above is double dutch to me.
I get emails (sometimes with links) from friends and family. Some links that use to work, longer do. instead aforementionbed message appears.
The message is a flowplayer message which basically displays flash (as in adobe flash) images.
This error was fixed quite a while ago and even if the site you are viewing has an older version then there is some workarounds.
Do you have an example that you could post? If not (I'll understand as you might not want to post links to family images etc) then can you describe what you expect to see with these links? Photos? Videos? etc.
  • Thanks
Reactions: DP
Thanks for tryuing to help Kris. Looks like even if you gave instrcutions, I would not be able to fix the problem.
My son will be coming home in couple of weeks. He fixes the problems on the PC.
Thanks once more.
