    Dismiss Notice
Error E22 Hoover Condenser Dryer
Discussion in 'Appliances' started by Jonathan Hackett, 21 Feb 2021.
  1. Jonathan Hackett
    Jonathan Hackett
    21 Feb 2021
    7
    Thanks Received:
    Country:
    Hello everyone.
    We’ve had our Hoover Tumble Dryer for little over 3 years now, and with 2 small kids it gets quite a bit of use as you can imagine.
    Recently I had noticed that the machine wasn’t drying clothes as effectively as it usually did and planned to give the condenser a good clean, however before I got around to it, the machine began giving me an E22 error message.
    I gave the condenser a good clean out thinking that it might solve the issue, but no such luck.
    I’ve checked my manual and found no information regarding error codes and my Googling hasn’t pulled up many trees either.
    Many thanks to anyone who is able to help point me in the right direction on this one.
    Brand: Hoover
    Model: HL C9DCEB-80
    Error: E22
  2. Sponsored Links
  3. Harry Bloomfield
    Harry Bloomfield
    30 Dec 2018
    9,455
    Thanks Received:
    1,279
    Country:
    E22 suggests condensate pump or its drain is blocked.
  4. Jonathan Hackett
    Jonathan Hackett
    21 Feb 2021
    7
    Thanks Received:
    Country:
    Thank you for taking the time to reply Harry, I really appreciate it.
    I have done some further Googling based on your suggestion and will check this out and see if we can get some life back in the machine.
    Would you happen to know if I am able to access the Condensate Pump without needing to open up the machine and remove the drum on this model?
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
