We have just had a problem with our back upvc door and after following other threads on here i found the cam on the euro cylinder has moved out of alignment.
I have sourced a new cam and the size i need to replace like for like is 40 x 50.
However, this size sticks out of the door by 5cm on the inside and 10 cm on the outside.
I read on here that when replacing get one that is flush with the door
By my reckoning this means that i should get a 35x40.
Is this correct or should i just stick to the original size?
Thanks in advance
Thanks in advance
