european taps
  • Thread starter Thread starter wsd
  • Start date Start date
wsd
9 Oct 2007
London
we used to have a perfectly good system - bath filled in minutes, could use shower attachment to have really powerful hair wash - ( we have conventional boiler and hw cistern - )
then installed new bathroom suite with new taps - hopeless - takes forever to fill the bath - get no water at all out of the shower -
had advice to get combi boiler but reading all the stuff on your website this does not seem to be the answer at all -
is there somewher we can get taps that still let the water through????
should of said you had gravity system not mains pressure when buying taps.
still get taps for lp but design is limited and getting harder to find modern ones
Was any of the pipework to the taps altered or were the new taps a straight swap. Have any isolation valves been fitted below the bath - if so, maybe they aren't fully open? What's the pressure like at the basin - has it the grunt of old?
thanks for speedy responses - there were some minor alterations to pipework but basically straight swap - but apparently the new taps wont take the 3/4" like the old ones and then they have the ceramic disc thing - yes the basin taps are much slower too but that is not so much of a problem - any ideas where I could find suitable taps even if hard to find?
ceramic disc taps or 1/4 turn the holes are so small gravity is no good and alot of bath taps now are going for 1/2" instead of the 3/4"
just got to look around depending where you live round here we are lucky with many bathroom /plumbing stores.
but the bigger ones like plumbcentre, b&q etc sell the same old rubbish nothing different.
