    Dismiss Notice
EUROSEC CP8L anti-tamper / rewire
Discussion in 'Alarms, CCTV & Telephones' started by jacko555, 4 Feb 2021.
  1. jacko555
    jacko555
    5 Feb 2005
    507
    Thanks Received:
    65
    Country:
    I have an inherited EUROSEC CP8L.
    Am redecorating and need to relocate /replace some sensors. I'm able to run new alarm cable although curious how to do connect it without setting the alarm off. I do have the installer code and the user code.
    My only experience so far was when we moved in - there was a power cut and the alarm went off. Have since replaced the battery.
    So:
    Does the C8PL have any anti tamper alarm on the PIR sensors? Is there a procedure I need to follow to disconnect / relocate a sensor?
    Do I need to power it down first? When there's no mains power, and, the battery is removed, the alarm goes off. I dont have easy access to the bell box...
    Thank you
  2. Sponsored Links
  3. The Pars
    The Pars
    17 Feb 2017
    119
    Thanks Received:
    23
    Country:
    Put the panel in installing mode and this deactivates all tampers.
    Remove the +12v on the panel PCB(this will cover down the PIR's).
    Once you have connected/replaced the sensors put the 12v cables back, put panel lid back on, come out of installer mode and do a walk test.
    Remember to keep the wiring colours the same at each end.
    • Thanks Thanks x 1
Loading...
Share This Page
