eurosec cp8l
19 May 2021
hello everyone ..... i hope somebody can help me........ my eurosec cp8l is working perfectly, with no error messages.... no low battery warnings etc..... however the other day i had to turn the power off in a part of the house..... i tripped the rcd that i needed and the alarm went off..... could not reset on the keypad, because that has no power.... how do i overcome this problem, and if there is a power cut in my area the alarm is obviously going to go off.....
if the battery in the control box was low, would it not give me a low battery warning...
thanks very much
if you remove mains power and the system goes down, then panel battery may have failed.
thanks for that....... yes it was the battery..... replaced and now all ok..... it threw me because i had no low battery warning on the dispay.... cheers
