Evohome BDR91 connection with Worcester 28CDI
19 May 2016
Hi
I have bought a Evohome WiFi Connected Thermostat Pack (ATP921R3100) and the HR92 radiator valves.
Please can you help in getting BDR91 relay box connected to the boiler.
The actual connections of the boiler are as pictured:
the main cable has 5 cables (brown, blue, green yellow and two black)
the white cable in the picture has (blue, brown and grey) which I believe it is going to the thermostat
The boiler manual:
Many thanks
If you can't figure out fig 13 then can a professional.
This
If you can't work out that very simple wiring, you have absolutely no hope of being able to set up your Evohome successfully - it's not really designed for DIY installation and Honeywell won't help you
