Hi All,
I need some advise on which option to choose during a guided setup please.
System details:
Is the above right for my setup?
System summary shows:
Stored Hot Water - 2 two port or three port valves
Living room - Single zone, evotouch sensor
System Devices shows:
Boiler Control - None
Stored Hot Water - Enabled
Is it ok to have Boiler Control as None?
TIA!
System details:
- Home Install
- No HR92’s (yet)
- S-Plan with two Honeywell control valves for CH and HW
- Unvented pressurised hot water tank
- Worcester boiler
- 'FACTORY RESET' evohome Controller and then 'HARD RESET' by removing batteries for several minutes.
- Fully clear the 'binding' on both BDR91's (press and hold the button on the BDR91 for 20 seconds). Both HW and CH BDR’s are doing a short red flash.
- Power evoTouch display back on, now shows “guided configuration” and “Installation Menu” as options. I chose Guided Configuration.
- Asks “Do you require to control the heat demand (boiler)?”. I select red cross as per point 10 in above mentioned instructions.
- Asks “Do you require to control a Stored Hot Water cylinder?”. I select green tick.
- I bind Hot Water Sensor
- Asks “What kind of valve(s) do you use to control flow to Hot Water cylinder and heating?”. I select “2 two port or three port valves”.
- I bind Hot Water Valve to BDR controlling HW
- I bind Heating valve to BDR controlling CH
- *Here is where I get stuck*
- Asks “Select the heating type for the zones you are creating” and gives:
- Underfloor Heating
- Mixing Valve
- Radiator Valve
- Zone Valve
- I have no radiator HR92 valve, so what do I choose? Each one I’ve tried always asks to bind an actuator after choosing the following:
- Select number of zones to create: “1”
- Press to edit zone name: leave default as Living room
- Use evotouch as the temperature sensor for living room: Yes
- Now says “Press BIND button on actuator(s), then press BIND button below.
- It seems my only option is to bind the CH BDR again because if I don’t, the main screen says no bind.
- Once bound it says (1 actuators bound 2 way).
TIA!
